Trans swap
jddevlin2007
I did the crappy 3 speed automatic to 5 speed manual swap a few years ago. It's not especially difficult. Do watch out as not all the tranny parts are mix and match. If the donor car is not a turbo, you will have to use the rear differential. The gear ratio on the turbos are 3.7 : 1, where the non-turbo models are 3.9 : 1. Mismatch and you'll do all sorts of damage if you try and drive the car. And yes, the front half shafts are also different. I'm pretty sure the rear halfshafts are the same, though don't quote me on it.
