Kwhistle Posted January 4, 2010 Share Posted January 4, 2010 (edited) 98 OBW, been having this issue since got the car some 6 weeks ago. There is an oil leak on top of the engine, passenger side. I've been blaming it on the power steering leak, and it did seem like the pump and the fluid tank o-ring were leaking. Finally fixed both yesterday, 1-minute liquid gasket seems to have taken care of it, and no leaks around it today. But I was looking at it outside in good light, and noticed another oil collection that seemed to be around the tip of the head gasket that you can see from the top. I tried to take pics, but they didn't come out well enough to see it, will try more later if needed. I hope that's not the head gasket leak, but really I can't think of anything else that could be leaking oil in there. If I were to estimate, it leaked about an oz a day before, and mostly collected right under the steering fluid reservoir. I haven't noticed any appreciable drops in oil level. I'm pretty sure that it's not the valve cover gasket because those are nice and clean. Also haven't noticed any signs of possible oil/coolant mixing when I changed the oil last week. The only thing that bugs me a bit is a drop of oil on top of the oil pressure sensor. I'm pretty new to the DIY thing and to Subarus, so apologies if my questions are totally off the wall, and really appreciate all the info and advice I get from the experts here. I hope it's not an HG, and that it really was the PS fluid, but want to make sure just in case. Could HG only leak oil and not oil + coolant? Edited January 4, 2010 by Kwhistle Link to comment Share on other sites More sharing options...
bheinen74 Posted January 4, 2010 Share Posted January 4, 2010 try to replace the oil sender? look for one from a junkyard car thats still dry, or buy new OEM if you can afford it. The only time they fail is when they leak, so if you find a dry one at a yard, get it Link to comment Share on other sites More sharing options...
Kwhistle Posted January 4, 2010 Author Share Posted January 4, 2010 I think the OE pressure switch is about $15, but it really doesn't look like the problem. It's all dry around it. The problem is more below the PS fluid tank and the area just to the side of it. Here's a pic, with red arrows where I've noticed the oil before, and blue where I noticed it today. Link to comment Share on other sites More sharing options...
bheinen74 Posted January 4, 2010 Share Posted January 4, 2010 i can see your oil pressure sendor, its fine in that pic Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 4, 2010 Share Posted January 4, 2010 Clean it out of there and see if it comes back. Link to comment Share on other sites More sharing options...
idosubaru Posted January 4, 2010 Share Posted January 4, 2010 Clean it out of there and see if it comes back. +1 make sure it's not just old PS fluid draining elsewhere? let's hope for good luck on this? i realize this doesn't mean much but i haven't ever seen a head gasket leak like that. Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 5, 2010 Share Posted January 5, 2010 I have seen them leak like that, but they usually also leak into the combustion chamber or coolant passages. Link to comment Share on other sites More sharing options...
