86subaru Posted January 5, 2010 Share Posted January 5, 2010 buzzing noise coming from main fuse box under hood , located which one the 2 black breakers closes to the drivers side strut ,but only does it when it is real cold out 10-15 degrees , checked both out all clean , should i replace or nothing to worry about,right before i start the car, Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted January 5, 2010 Share Posted January 5, 2010 Sounds like a bad relay, or one with a bad connection. Open the fuse box lid and touch the relays with your finger until you find the culprit. What could happen depends on what the relay is for... Dave Quote Link to comment Share on other sites More sharing options...
86subaru Posted January 5, 2010 Author Share Posted January 5, 2010 (edited) ok, i'll change both will autozone carry them or special order ? well found spares but from a 95 lsi 2.2 denso type are the same 4 Edited January 5, 2010 by 86subaru Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted January 6, 2010 Share Posted January 6, 2010 I had a buzzy relay on a VW some time back. The relay still seemed to work, but I replaced it anyway. I figured it was cheap insurance to replace before it caused trouble. Quote Link to comment Share on other sites More sharing options...
86subaru Posted January 6, 2010 Author Share Posted January 6, 2010 (edited) yes, my spares were different will not work,but the strange thing is only makes a noise when it is cold out checked #rc 5001 and rc 5008. 3 of each . Edited January 6, 2010 by 86subaru Quote Link to comment Share on other sites More sharing options...
86subaru Posted January 9, 2010 Author Share Posted January 9, 2010 replaced both relays making noise , still getting buzzing , no hard start , runs fine , does not buzz all the time , very cold outside, everything is off , here is one thing there is a remote start ,but i have no remote to use it, Quote Link to comment Share on other sites More sharing options...
