front LSD for my RX is it possible?
Yes, the most common one people have used is the phantom grip one. I think that is the correct name?
no. Phantom Grip does not make anything for subarus, Mud-Rat put a phantom grip in the front of a D/R 5MT, and it blew up not long after.
the cliff notes from that thread linked (and there's one more recent in the retrofitting section), is the front diff is the same for all subaru 5MTs. now, only a handful of the highest-end jdm 5MTs got front LSDs, so finding a used one in decent shape is unlikely. But, many companies make aftermarket ones...
But be prepared to shell out a grand for a cheap one, and 3-4 for a nice one.
Also, WJM put an aftermarket front LSD in his RX. and after a few events, his comment was that it wasn't enough to compensate for the open center diff. a stock EJ center LSD would be a much better improvement.
  • 9 months later...
Where and when did I say that?
I purchased the OBX unit for $358 shipped but never installed it.
A front helical LSD for a vehicle used primarily on PAVEMENT would be the best improvement.
Installing a VLSD center would be worthless on the same application. 5MT WRX's are junk when trying to drive spirited. The RX was just a tad worse due to absolutely no LSD there.
Doing BOTH the front and center would yield awesome results.
HOWEVER, if you have one or both:
1. Too much power.
2. No enough tire/suspension grip.
A front LSD isnt going to do you much good and a center LSD will do you less than what a front LSD will do.
Again, doing both solves a lot of problems. Of course, proper tire/suspension grip AND proper power level (you can add more with other items corrected) + LSD diffs solves the problem completely.
