So, is this bunch just too cheap, or does noone have aftermarket wheels? I have a bent factory on my 02 OBW, and thought it would be a good time to jazz it up a little. After doing a search on here, all I come up with is: the factories have a 56.1mm center bore, a 48-55mm offset, and a 5x100 bolt pattern. I see multiple mentions of the aftermarkets being mostly 35mm offset, and implications of premature bearing wear. Seriously? I just can't see 10-15mm making that much of a difference, other than it looking screwy for sticking out too far. I'm not looking to break the bank, but I would like something other than the boring factories. So, let me see some pics; what have you done?
You can find a big selection of inexpensive wheels with the correct offset at TireRack.com; just choose a set you like the look of. I got mine for $100 each, and a few weeks later they went on sale for $69 each. The folks at TireRack are good to deal with; they even called me up because I went with a non-standard fitment (235/45-18 on 18x8 wheels with a 48 mm offset).
