trikerbob Posted January 8, 2010 Share Posted January 8, 2010 Hi guys, got a question for you. Will the EJ 2.2 motor bolt up to the Auto trans of the EA82 1986 car? This would be used in a Trike build so no problem with sensors of other wiring issues or fitment problems. What needs to be done to make them work together? Thanks, Bob Quote Link to comment Share on other sites More sharing options...
GLCraig Posted January 8, 2010 Share Posted January 8, 2010 I do not think anyone has done that yet because the EA81/EA82 3-speed automatics had enough problems with the far less powerful EA81/EA82 engines. There are adapter plates that are intended for mating a EJ22 to an EA82 manual transmission but since this is for a trike you probably will need an automatic. If there's enough room on your trike, a 2wd 4EAT, 4-speed automatic, from a 90-95 Legacy or 93-95 Impreza would be a better option. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 8, 2010 Share Posted January 8, 2010 No, it won't bolt up. You need an adapter plate. Since EA82 engines/trans are all interchangeable and identical from a "bolt up" stand point, then what you're asking has been done countless times for a long time and well documented using adapter plates. try searching for "adapter plate" if that's what you're after. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted January 8, 2010 Share Posted January 8, 2010 If you try to make something custom, the bottom studs line up the same, and the pilot hole (in a manual) lines up the same. The adapter plate needs to be 12mm (or 1/2")thick to make up the difference in the EJ22 bellhousing vs the ea82 motor. I would imagine the ej22 flex plate would bolt to the ea82 torque converter the same. use the ea82 starter Quote Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted January 9, 2010 Share Posted January 9, 2010 i got a rebuilt 93 imp 4EAT down in turlock that'll bolt up to your EJ. i've been sitting on it for months and i'd let it go cheap at this point and throw in every 4EAT related part i own - i don't own any auto cars and i don't plan on changing that. let me know. Quote Link to comment Share on other sites More sharing options...
trikerbob Posted January 12, 2010 Author Share Posted January 12, 2010 Thanks guys for your responses to my questions. I kind of figured it wasn't going to work without an adapter. This info is for a friend of mine who already has a left over EA82 trans that he wants to use just because he has it and it was a freebee. So he might just go ahead and stay with the Ea82 motor, but he has been interested in the EJ22 with the mods to Dist and carb for the extra 400cc's it would bring to the project, but it might not be worth the extra problems it will take to mate them up. We'll just have to wait and see. Quote Link to comment Share on other sites More sharing options...
Qman Posted January 12, 2010 Share Posted January 12, 2010 No, it won't bolt up. You need an adapter plate. Since EA82 engines/trans are all interchangeable and identical from a "bolt up" stand point, then what you're asking has been done countless times for a long time and well documented using adapter plates. try searching for "adapter plate" if that's what you're after. Has been done countless times with a manual trans. The automatic involves a whole new set of problems. Using a 4EAT from a Legacy as mentioned above is the answer. Quote Link to comment Share on other sites More sharing options...
Suberstar88 Posted January 12, 2010 Share Posted January 12, 2010 Save the headache, those Guma 3 speeds are absolute garbage(I drive one) find an 4AT, it will bolt to your ej. Quote Link to comment Share on other sites More sharing options...
