RX trans and LSD fluids!
Zefy
i did a search but i didn't really put my heart and soul into it. so here i am asking the question.
what fluid should i be using in my 87 RX trans and 87 RX LSD rear diff?
I'm sure 75w-90 is fine for the trans. but what about the diff? I've only ever changed the fluid on newer subies with viscous centres and viscous rears. Thinking the RX might be a bit different?
i have access to a drum of 75w-90 subaru 'extra-s'. The good shtuff...
  • 4 months later...
bump from the dead... is this the only thing needed for these diffs? or is it an additive? found it on subarugenuineparts.com for 18 bucks for 1liter using your part number.
It is the only thing in my LSD. Filled the diff with it 6 years ago and no problem.
Sounds like its about time to change it. Even if you haven't put a ton of miles on it, the used fluid can start to do some bad things if just left to sit.
That subaru part number looks to be just a bottle of additive, but I could be wrong.
When I recently swapped to RX running gear in my wagon, I used some royal purple gear oil, that already had the LSD additive in it.
Redline also makes an excellent standalone additive you can use.
  • 3 weeks later...
