wtdash Posted January 13, 2010 Share Posted January 13, 2010 (edited) Can these two Phase 2 engines be interchanged? Just swap the Intakes? Or is it like the EGR issue w/the Phase 1 EJ25>>EJ22 swap, which will give a CEL w/out the EGR? Edit: And does the EJ22 still work w/either the MAP or MAF-based system? I know I can swap intakes (thanks to 'subaru360') on either the 2.2 or 2.5, too. Based on Wikipedia and a couple other sources these EJ25 SOHC engines came w/either MAF: EJ253 or MAP: EJ251. And what's weird is they weren't consistently applied. The '99 EJ251 (MAP), was replaced by the EJ253 (MAF) in '00, and returned in '05??! :-\ Thanks for any clarification. Edited January 13, 2010 by wtdash Link to comment Share on other sites More sharing options...
wtdash Posted January 15, 2010 Author Share Posted January 15, 2010 Anyone got anything? Thanks Link to comment Share on other sites More sharing options...
johnceggleston Posted January 16, 2010 Share Posted January 16, 2010 i doubt i'll know the answer, but i would need the year of each to even begin to answer. Link to comment Share on other sites More sharing options...
wtdash Posted January 16, 2010 Author Share Posted January 16, 2010 I'm looking for interchange info between the Phase 2 EJ25 (and the EJ22 Phase 2) between the '99 and 2005 model years. The only thing I know is the Forester I may buy is an '01, which means it should be the MAF-based EJ253. I think I'm making this more difficult than it is, since I'll be swapping intake manifolds anyway, whether it's a MAF or MAP-based system shouldn't matter, as I don't think they're on the engine. They're part of the air intake system, which won't change if I swap motors. Thanks Link to comment Share on other sites More sharing options...
Durania Posted January 16, 2010 Share Posted January 16, 2010 I'm looking for interchange info between the Phase 2 EJ25 (and the EJ22 Phase 2) between the '99 and 2005 model years. The only thing I know is the Forester I may buy is an '01, which means it should be the MAF-based EJ253. I think I'm making this more difficult than it is, since I'll be swapping intake manifolds anyway, whether it's a MAF or MAP-based system shouldn't matter, as I don't think they're on the engine. They're part of the air intake system, which won't change if I swap motors. Thanks The 2001 Forester is going to be MAP based, just like the RS's. So that means that 98-99 is MAF where as the 00-01 is MAP. Link to comment Share on other sites More sharing options...
