Ticking-sorta- noise when cold
On both my 97 and 98 Legacy wagons (2.2l) there is a noise after starting a cold engine. It is like a tick, but sounds like something plastic- more like a pocka pocka pocka - okay don't laugh.
Searched all the threads on ticking, but this is not fast enough to be lifter tick., With the engine at idle, is sounds like only once per revolution.
Both cars have 150 - 170,000 miles and have been properly maintained- as far I can tell. Don't know if the lash has been checked lately.
Been doing this for a year at least, and never worried about it. Goes away after about 3 or 4 minutes driving.
Do I need to be concerned about it?
i would search for piston slap and see if that's what you're experience.
other causes of ticking noises are failing timing tensioners, and will cause no other issues.
oil pumps can cause noises too from what I've "heard" but i've never *seen* it before so not sure. doubt that's it though.
Piston slap.
Nothing to worry about really unless it never goes away.
nipper
And even then it's really nothing to worry about. My mom's 98 2.5l has been tapping loud, all the time, and has lasted 163k, 50k that we've had it. You can hear it coming, tak tak tak. Never goes away, runs fine and gets mid 20's for gas milage.
We got the car with horrendously blown head gaskets, like as much exhaust out the radiator as the tailpipe. You could hear it breath through the radiator as you cranked it. If I had known how bad the pistons were I would have replaced them when I had the heads off. Hasn't seemed to be a problem though, more of an annoyance.
