monstaru Posted January 14, 2010 Share Posted January 14, 2010 does anyone have the fsm's for either of these.or know how to get the clutches off? the ea81 compressor is a york model, by borg warner.i am going to use it as an air coimpressor, i need to change the pulley over to the ej one.how do i get it off?regular ol' 3 jaw or what?cheers, brian Link to comment Share on other sites More sharing options...
The Beast I Drive Posted January 14, 2010 Share Posted January 14, 2010 If it's a York compressor, you should be able to follow the York procedure for removing the clutch. As for the ej compressor, I have no idea... -Bill Link to comment Share on other sites More sharing options...
Scoobywagon Posted January 14, 2010 Share Posted January 14, 2010 Generally, you back the nut off with an impact gun and a strap wrench. Then you get out a 3-jaw and hope you don't break something. Link to comment Share on other sites More sharing options...
monstaru Posted January 15, 2010 Author Share Posted January 15, 2010 right, but there has to be a tool to get the clutch off of the EJ.i mean.there is a recessed area that is threaded....cheers, brian Generally, you back the nut off with an impact gun and a strap wrench. Then you get out a 3-jaw and hope you don't break something. Link to comment Share on other sites More sharing options...
