Weber Swap
Gettin ready to swap to a weber,but I have a few questions.Is the connector for the electric choke the same or will it need need to be modified?What needs to be added if I get a carb with the water choke.The adapter plate,does any one have a picture or sketch of what it looks like.I could probably make it if I could see one.Does the coolant hole on the manifold get blocked off by the adapter plate or is there a hole for that too?And finally does any one have pictures or diagrams of the hose connections.
Thanks
I guess I should have mentioned what I was puttin' it on.84 gl hatch 4wd.It doesn't have power steering.so I can put it on straight,right?Bear with me I'm still kinda new to this site.Have been reading for weeks but not posted much.thanks for the info
Yeah well what sucks is that I made those pics a couple years ago and forgot I had 'em. I should have shared a long time ago but forgot they were on my harddrive. Maybe they could they be added to the Weber installation info on the USRM?
For those making their own adapters from scratch, a decent bimetal hole saw is all that's needed to bore the big hole. Works quuite well on soft aluminum.
