Cool Simple EA82 Oil Fill Tube Mod!!!!
OK. Here's one for you. Those of you who have an EA engine, and HATE the perpetually loose oil cap? Ever wonder if an EJ oil fill spout would fit on an EA82T? YEP!!!!!!!
[ATTACH]7273[/ATTACH]
You have to drill the bolt holes a bit bigger. The EJ tube has an o-ring slot. You might be able to find a big enough o-ring to seal it. I didn't and was in a hurry, so I simply made a gasket for the engine / oil fill tube.
(Yes, I posted this on a different thread, but that threat is very long, and though this mod deserved one all it's own)
hahaha i´ve lost 3 of them from many of my EA-82´s, so now i just bend the tabs on them slightly so it sits more tight on
I used to do that, but that only works for so long. It is a really easy mod. I used to have an EA81 GL. It was a very long time ago, but I'm almost certain the oil fill on the 81's and 82's are the same.
I lost my cap on my 83 wagon.Now Im running the lower half of a MT dew can.Its just as tight as the stocker..especially cause the can is crunched down tight n the oil fill tube...Never thought of useing the legacy style filler...
