bobaru Posted January 17, 2010 Share Posted January 17, 2010 (edited) whats the differences in the motors beside oil capacity? Is the 4.2 a solid workhorse like the 4.8 Edited January 17, 2010 by bobaru Link to comment Share on other sites More sharing options...
The Beast I Drive Posted January 17, 2010 Share Posted January 17, 2010 What? -Bill Link to comment Share on other sites More sharing options...
Durania Posted January 17, 2010 Share Posted January 17, 2010 (edited) Huh? Oil capacity? Edited January 17, 2010 by Durania Link to comment Share on other sites More sharing options...
OB99W Posted January 17, 2010 Share Posted January 17, 2010 (edited) Huh? Oil capacity? Yes, some of the 4-cylinder engines are speced for 4.2 quarts oil capacity, and some for 4.8 quarts. I seem to remember some WRX and STi engines having the higher capacity. Perhaps someone else will have the full details. EDIT: Turbos can certainly benefit from more oil capacity, so that might be part of the reason. The new small oil filters also lower the overall capacity a bit. Edited January 17, 2010 by OB99W Link to comment Share on other sites More sharing options...
bobaru Posted January 17, 2010 Author Share Posted January 17, 2010 (edited) What? -Bill yes my ? is :confused:ing I found out ther's 2 different motors oil capacity two port heads hydro VS solid------how often do they need adjusting interfernce heads I know the 90-94 is a realy good motor its the 95 96 is what im asking about ........How good dose it stand up to the gen1 leg and are there any no no s Im lookin at a 96 leg. Edited January 17, 2010 by bobaru Link to comment Share on other sites More sharing options...
bobaru Posted January 17, 2010 Author Share Posted January 17, 2010 Yes, some of the 4-cylinder engines are speced for 4.2 quarts oil capacity, and some for 4.8 quarts. I seem to remember some WRX and STi engines having the higher capacity. Perhaps someone else will have the full details. 4.8 quarts motor in the gen1 legs thats all I know and its a damb good motor its the 4.2 I know nothing Link to comment Share on other sites More sharing options...
idosubaru Posted January 17, 2010 Share Posted January 17, 2010 I like the 95 and 96 better than the earlier generations. they always seem messier in the engine bay, 95+ seems simpler but maybe that's just the nature of older motors, worse maintenance, etc. either way, same great motor, no issues to be found. 97+ is an interference engine and a slightly less reliable timing tensioner design. 96 should still be non-interference. Link to comment Share on other sites More sharing options...
subaru360 Posted January 18, 2010 Share Posted January 18, 2010 The squared off bottom oil pan takes more oil than the rounded bottom oil pan. It's got nothing to do with reliability. You can use any EJ oil pan on any EJ engine. Link to comment Share on other sites More sharing options...
