Let's see your LIFTED Soob off roader 2010 edition.
ezapar
Last months snowmobiling pics.
Around 8,000ft on Uinta National Forest Snowmo trail.
Basically stock 1982 Subaru GL Hatch.
Modifications;
Light bodywork done.
Non-factory wheels rims.
Stays on top of the snow well! :banana:
Here is the 03 H6 L.L. Bean gettin high. Mom loves the cushier ride and easier entry/exit of this mild lift.
The lift is our newly designed HighGuys 2 inch 3rd Gen Legacy kit. Check out the thread in Vendor forum.
  • 2 weeks later...
okay, another wheeler in my fleet :grin:
what I did to get it going again...
new front rotors and calipers
ea82 coilovers in rear with new custom mounts
4" engine crossmember and strut tower blocks
lengthened steering shaft
new aftermarket headlight switch
fixed wiring for:
-headlights
-horn
-hazards
-center lamp
-ignition switch (aftermarket)
replaced missing front turn signal wire harnesses
hood pins
replaced heater hose
beat down rear bumper to normal position
tapped threads and reinstalled rear bumper ends
front RooBar installed
fixed wiring to thermo-switch on radiator
added wiring for fog lights
'84 style mirrors replaced broken '82 style ones
tightened up steering column mount bolts
new hazards flasher
removed cruise switches (rest was removed long ago)
15" pug flat spoke alloys with 27x9.50x15 SSR SWampers
still to do:
new thermo switch for radiator
sloppy shifter fix
exhaust rattle
weber tuning...
What is still has from previous builds...
portions of BYB Lift Kit from Australia
xt6 alt.
accel coil
weber 32/36 carb
rear disk brakes
EA81 GL-10 cloth interior
newer radiator
newr heater core
Autralian rear seat shoulder belts
87 wagon 4" sjr lift 5 speed Dual range 1.8 FI 29" maxxis bighorn's 6 lug mod and 15" kidney bean slotted alloy rims, high end stereo, custom led interior lighting (underglow kit)
old rims
new rims and tires
subaru playin at ocean shores
and again (must think its a monkey climbing on stuff like this)
Edited by True2Blue
This is the newest one and by far the nicest one that i own.
Mods are:
4" SJR
27" BFG AT's
Allied Armament wheels 15's
Yakima rack
Stock ea82 with D/R 5 speed
New cat back with flowmaster
Alpine deck with 4 Focal speakers
Cobra CB
Soon to come mods are"
Tube bumpers front and rear
10,000lb winch
Window tint 20%
LSD if i can find one
GM100 amp
-cody
Edited by sube4x4
  • 3 weeks later...
i guess i should post up mine. i've had this wagon for a long time but i haven't really used it. only taken it out on the trails once (and broke it once...) then i DD'd it for a bit when the impreza was under the knife...
anyways...
87 GL wagon
-134k original km (84k miles)
-d/r trans blah blah
-lifted 2" via "one eye" lift
-welded rear with a spare diff and axles
-28" BFG M/T's on pug 505 turbo wheels (thanks zap!)
plans
-hit some stuff
-fix other stuff
-make a fool of myself with all my toyota buddies......... nobody wheels subies here.....
and my DD is also technically lifted on forester suspension.... weeeeeee...
99 impreza TS
-NEW ej253 from RS
-fozzy XT suspension, wrx wagon springs in the rear
-06 wrx seats
-rocket rally short throw shifter
-wrx rear brakes and 2.5rs fronts
-5 spoke goldies with summer tires, TS 6 spokes with kumho studded, 93JDM 5 spokes with kumho r-comps, steelies with falken gravel tires and a spare set of legacy alloys for good measure... :lol:
-sti trans mount
-solid diff mount
-80W/100W headlights with hella 500 spots...
-custom yakima roof rack with thule spirit box.
picture.php?albumid=34&pictureid=2436
Taken just this last weekend up in the Wallowas in Eastern Oregon, 5000' elevation plenty of snow left.
picture.php?albumid=153&pictureid=1368
Last year's run to Bennett Peak, Wallowas Eastern Oregon
My daily driver/trail rig:
'92 Loyale
4" AA lift
EJ22 w/ 2 1/4" Magnaflow exhaust
SJR adapter plate
K&N filter, Perrin Pulley, Perrin rear diff cover
5 SPD D/R transmission
Rear LSD
Rear disc brakes
Warn EA82 front brush guard
Primitive Racing front skid plate
XT6 front seats
14" Pugs with Wildcat AT's
Various interior bits from GL's
Still trying to find some decent All terrain tires that fit a 14" pug.
Edited by cmiller
  • 1 month later...
27inch tires on drilled six lug rims
6inch daylighters
reasonably sized spair as apposed to the factory spair.
stock suspension
tailight gaurds(function somewhat to a degree)
stripped interior
stock drivetrain ea82 carbed
glass pack exhaust
15inch custom tube sub. powered by an old 500watt clarion amp
stragetically placed dents for aerodynamic advantages : D
(sorry camera phone sucks)
Edited by 87glsubie
very very crummy pic i had to change it
1981 GL Wagon D/R
4" lift
Turbo Muffler
SJR wheel adapters/VW wheels
28" BFG MT K2's
Kenwood head installed sweetly
Future Mods:
Fix what little lower door rust I have (dam that looks neglected)
Rear Disk conversion (need time, got stuff)
6 Lug Conversion (gotta use these yota wheels I have)
Build a bumper for my 6,000lb warn
Mount my set of Hella's
Install 50 cal machine-gun on roof with wireless remote control
picture.php?albumid=254&pictureid=2535
We had 2 decent snow events here in the mid-south this spring.. Darn Glad I decided to tackle the lift of this rig last fall... I had a blast here in the Ozarks with 12"-14" of snow on the ground.. :banana:
picture.php?albumid=254&pictureid=2536
========== I never claimed to be a great photographer..
think that's it..
thanks!
Edited by Zap
typo
  • 3 weeks later...
Just thought I'd post this, since the transmission just went out and the rust means it probably won't get fixed (that's 2 for us this year...). it's my Dad's.
'94 Legacy GT wagon (yep, raised roof). Essentially a home-made first-gen Outback.
stock 2.2 and 4.111 5MT
BG Outback struts and springs
WRX wheels with 205/60r16 tires
t-leg front brakes
how it looked when we got it 3 or 4 years ago. $350 on ebay :banana:
we put about 100k on it since then.
This topic is now closed to further replies.
