New head gasket (air escaping through valves)
I put a new headgasket on my ea82 and it's still going nowhere fast. I know I should have had the head checked and possibly shaved but I really don't have the cash. Anyway, now that I have the headgasket on air is escaping through the valves, is there a cheap way to have them rebuilt or should I be looking for a junkyard motor. I'm at a loss.
Thanks
  nipper said:
At the very least you should have lapped the valves. Get a price for having the heads checked, otherwise you may be buying a third head gasket.
nipper
They wanted $160 to pressure test the heads. I chose not to lap or grind the valves initially because I don't have a spring compressor. I'll have to see if I can rent one and invest in a lapping kit or grind tool.
