Coolant Oil Milkshake
^^^ as above. Didn't drain coolant before removing intake... (that's a bad idea for future reference).
So I figure... no big deal. New Oil/Filter just had the crap oil and fram that i used to get it running. Guy at parts store says i need to flush with new oil filter and THEN get new filter and oil. Something about coolant being very bad for rod bearings... So. I've got a 2 oil filters but do I really need to flush with 4 quarts of oil?
Did you run it after that? Did you take the spark plugs out to clear it before it started up?
Just do a normal oil and filter change. You're not going to get any extra out by changing the oil twice. You only do that if you're trying to clean sludge out , not coolant.
Thanks GD
Also realized that some rainwater might have went into the pcv when it was without a hose (fixed that).
After I flushed (wow.. atf stinks) and refilled there is still a TOD on the Passenger side. Kind of goes in/out at idle but is pretty noticeable. What might that mean? Car runs pretty good with the new weber otherwise.
