Junkyard for under $100, and maybe 3 hours work if doing it for the first time. Just have to match the ratio of the trans.
How do you figure that the rear diff is bad? What symptoms? What have you done to determine that it has a problem?
And no, just putting the FWD fuse in will not help if indeed the rear diff is toast.
