howards11 Posted January 21, 2010 Share Posted January 21, 2010 (edited) I noticed today that my rear washer was clogged again. But this time it's leaking into the cargo area. Does anyone know how the rear nozzle comes off ? Did I break a hose or is this a bad clog ? HELP ! ~Howard Edited January 21, 2010 by howards11 Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted January 22, 2010 Share Posted January 22, 2010 It should come out. If it's like the ones on the hood, there will be little clips that snap and hold it in place. Quote Link to comment Share on other sites More sharing options...
howards11 Posted February 1, 2010 Author Share Posted February 1, 2010 The hose broke where it comes into the sheet metal for the hatch. My mechanic coupled the 2 pieces and it works better than new. $100.00. All labor. ~Howard Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted February 1, 2010 Share Posted February 1, 2010 Suggest using a straight pin (needle) to poke inside the hole where the fluid squirts out. I have done that to break up crud dirt that can accumulate to get the washer fluid flowing again. Quote Link to comment Share on other sites More sharing options...
howards11 Posted February 1, 2010 Author Share Posted February 1, 2010 Suggest using a straight pin (needle) to poke inside the hole where the fluid squirts out. I have done that to break up crud dirt that can accumulate to get the washer fluid flowing again. I appreciate your suggestion but in this case the hose was broken and needed a repair. ~Howard Quote Link to comment Share on other sites More sharing options...
