GlTurbo1987 Posted January 21, 2010 Share Posted January 21, 2010 first off its a EA82T... I'm getting a weird cold start issue, but only when its below about 40 degrees or so... It starts up fine, idles fine, but once I start driving and the temp gauge starts to rise, it will start bucking like it isn't getting enough fuel. It doesn't do it with the clutch disengaged, it only happens when the engine is loaded. It will go away after the engine warms up a bit more, and I don't have a problem after that. Any ideas? Could it be the clutch slipping when because it is cold? or maybe the IAC? I tried searching the forum to no avail. Thanks in advance........ Link to comment Share on other sites More sharing options...
naru Posted January 22, 2010 Share Posted January 22, 2010 (edited) I would change the fuel filter and check the CTS connector for corrosion. Ignition system check after that. Edited January 22, 2010 by naru Link to comment Share on other sites More sharing options...
GlTurbo1987 Posted January 22, 2010 Author Share Posted January 22, 2010 Fuel filter was just changed about 1500 miles ago, and it happened before that.... also, it doesn't matter if its under boost or not, and it doesn't throw any codes when it does it... Could the spark plugs be causing it? Link to comment Share on other sites More sharing options...
