Megasquirt fuel maps
CHIM
Ok, so im getting close to finishing a megasquirt install on my nephews car, Anyone here using a megasquirt I that might have fuel maps for the EA-82 T's?
Maybe know a good place look? I am fully prepared to build one from scratch but wouldn't mind taking the lazy way and usuing someone else's homwork as a starting point.
I am interested to see how this turns out for you. You didn't happed to document this when you were doing it did you? I would be very interested to see how you did it, and to see the results!
I havn't really started yet but i think i might, Im building my own harness from scratch so i should be able to give ya somthin.
http://www.diyautotune.com/tech_articles/how_to_megasquirt_your_subaru_rx_turbo.htm
I would recommend not using the factory engine harness though, as it will cause you nothing but headaches. Either way, using the settings in that article will start the motor at the very least. I would not recommend using someone else map, as it could be nothing but problems. Far easier to just start frm scrach.
Edited by JWX
Oh no, im definatly not using the stock harness, made my own, just keep a few inches as pigtails.
Im hoping to have her running tomarrow.
