ericem Posted January 24, 2010 Share Posted January 24, 2010 Hey guys, just wondering do they sometimes leak?? I see oil coming out of one, but it might just be my oil pump itself leaking down doesn't seem like it though. Any ideas don't feel like pulling the belt and replacing the gaskets till spring. Link to comment Share on other sites More sharing options...
nipper Posted January 24, 2010 Share Posted January 24, 2010 Test plugs? Link to comment Share on other sites More sharing options...
ericem Posted January 24, 2010 Author Share Posted January 24, 2010 You know those two huge allen key plugs when you look at the bottom of the engine that are part of the oil pump? Link to comment Share on other sites More sharing options...
nipper Posted January 24, 2010 Share Posted January 24, 2010 AH galley plugs. nipper Link to comment Share on other sites More sharing options...
MilesFox Posted January 24, 2010 Share Posted January 24, 2010 probably the oil pump shaft seal is leaking Link to comment Share on other sites More sharing options...
nipper Posted January 24, 2010 Share Posted January 24, 2010 What year and how many miles on this car. When was the last time a timing belt was done and cam/main seals? Link to comment Share on other sites More sharing options...
davebugs Posted January 24, 2010 Share Posted January 24, 2010 Those allens don't leak. And they are usually TIGHT! But I really don't know what purpose they serve. Nipper has the correct questions. ALong with if the pump was ever off did they check the phillips screws to make sure they were tight and use an OEM crank seal. Link to comment Share on other sites More sharing options...
MilesFox Posted January 25, 2010 Share Posted January 25, 2010 depending on if you have an analog gauge, or a dummy lite, one or the other of the plugs is used depending on the sending unit. Link to comment Share on other sites More sharing options...
ericem Posted January 25, 2010 Author Share Posted January 25, 2010 It's a used motor so I have no history. It's not to bad ill just leave it till its warmer then ill overhaul everything. Link to comment Share on other sites More sharing options...
