pierman2 Posted January 26, 2010 Share Posted January 26, 2010 (edited) Are all ea 82 seats interchangeable? How about early legacies, foresters, etc? Edited January 26, 2010 by pierman2 Link to comment Share on other sites More sharing options...
idosubaru Posted January 26, 2010 Share Posted January 26, 2010 from what i recall EA82 seats are interchangeable. most EJ stuff is interchangeable, though there are some variations through the years. are you talking between EA82 or wanting to swap from EA82 to EJ? EJ stuff usually doesn't bolt right in to an EA82 but can be made to work. some EJ stuff will make you sit a good bit higher in the car if you fit them into an EA82. haven't spent much time in other EA stuff but in an XT it gets tight if you're tall. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 26, 2010 Share Posted January 26, 2010 Yeah - EJ seats will sit you higher when put into EA vehicles. Plus they require welding and other modifications to bolt up. EA82 seats are interchageable - sometimes you do have to swap the rails around as when putting Loyale seats (auto belts) into older GL's. GD Link to comment Share on other sites More sharing options...
Arthrogrian19 Posted January 26, 2010 Share Posted January 26, 2010 I'm thinking about swapping bases from my '08 FXT seats into my '91 Loyale. All I know at this point is that the FXT seats definitely do not bolt in to the Loyale. Link to comment Share on other sites More sharing options...
swixtt Posted March 18, 2010 Share Posted March 18, 2010 subscribed... i have a GL10 EA82 86 and really need something done with the drivers seat. hoping that i can find another one around. Link to comment Share on other sites More sharing options...
Redcap Posted March 20, 2010 Share Posted March 20, 2010 (edited) Plus they require welding and other modifications to bolt up. No, they don't. Edited March 20, 2010 by Redcap Link to comment Share on other sites More sharing options...
The Dude Abides Posted March 20, 2010 Share Posted March 20, 2010 No, they don't. Thinkin you want to lisen to GD man. Link to comment Share on other sites More sharing options...
rxleone Posted March 21, 2010 Share Posted March 21, 2010 No, they don't. *Sits back and waits for show to begin* Link to comment Share on other sites More sharing options...
Yo'J Posted March 21, 2010 Share Posted March 21, 2010 Just drilling and cutting and bolting if you don't have a welder. More things to watch loosen as you drive. I'm sitting in outback seats in my 82'. They are too big by the way and barely slide forward or back due to friction. Link to comment Share on other sites More sharing options...
Redcap Posted March 21, 2010 Share Posted March 21, 2010 Just drilling and cutting and bolting if you don't have a welder. More things to watch loosen as you drive. I'm sitting in outback seats in my 82'. They are too big by the way and barely slide forward or back due to friction. Nylocks. The driver's seat in my red wagon is a Legacy seat. Took about 30 minutes of my time to prepare and mount it to the EA82 seat bracket, including threading the spacer, the mounts on the Legacy seat and drinking a couple beers. Just drilling, no welding or cutting required. Link to comment Share on other sites More sharing options...
swixtt Posted May 4, 2010 Share Posted May 4, 2010 will Justy seats fit a GL10? the justy is about a 92 i think 4wd, auto, 4door. Link to comment Share on other sites More sharing options...
swixtt Posted March 14, 2011 Share Posted March 14, 2011 i'm still looking to change out these seats of mine. Link to comment Share on other sites More sharing options...
ernst82 Posted March 15, 2011 Share Posted March 15, 2011 Does anyone have any pics of their subies with different seats in them. I replaced my wrx seats with sti limited seats so I want to put my wrx seats in my xt Link to comment Share on other sites More sharing options...
Dj7291993 Posted March 15, 2011 Share Posted March 15, 2011 What about rear seats between a wagon and a coupe? (wagon to coupe) Link to comment Share on other sites More sharing options...
alexinvancouver Posted September 20, 2011 Share Posted September 20, 2011 (edited) I swapped my old seats on 86 GL hatch with newer (i think 04 wrx) seats which i find the most comfortable, even better than sti ones (i like them for removable headrests) bought them from wrecker for $180 and actually bought both passenger's side because they are usually in much better shape spent couple of days making bases and fitting the rails but quite satisfied with the results. can't wait for the next rally oh eah, and while on it i also made a hub from my old steering wheel and bolted Momo on it =o) Edited September 20, 2011 by alexinvancouver Link to comment Share on other sites More sharing options...
SoobDood05 Posted September 20, 2011 Share Posted September 20, 2011 I swapped my old seats on 86 GL hatch with newer (i think 04 wrx) seatswhich i find the most comfortable, even better than sti ones (i like them for removable headrests) bought them from wrecker for $180 and actually bought both passenger's side because they are usually in much better shape spent couple of days making bases and fitting the rails but quite satisfied with the results. can't wait for the next rally Oh man those seats look Shnazzy:slobber: +1 i am also wondering if seats out of an older GL or XT will bolt right in to my 90 loyale? cheers all! Link to comment Share on other sites More sharing options...
alexinvancouver Posted September 20, 2011 Share Posted September 20, 2011 (edited) i don't know if there's a direct fit but i'm sure one can make any seat fit as long as it's not overly wide for this seat swap i had to manufacture base and weld it to the new seats and then just bolted sliders to it. once i was driving my daughter's acura rsx and i though " man, these are the most comfortable seats"! and i was gonna buy those and make them fit. but decided to stick to OEM Subaru's parts so, why don't You just unbolt one of Your seats (it'll take couple of minutes anyway) and try what ever You like and go from there but i'd recommend to go with seats as newer as possible. BECAUSE IT'S YOUR back and butt man! Oh man those seats look Shnazzy:slobber: +1 i am also wondering if seats out of an older GL or XT will bolt right in to my 90 loyale? cheers all! Edited September 20, 2011 by alexinvancouver Link to comment Share on other sites More sharing options...
Turbone Posted September 21, 2011 Share Posted September 21, 2011 I put early Legacy seats in my 86 Brat, no pics of it. Put 90's Mitsubishi Eclipse seats in my 85 Brat. I had XT6 seats in my RX, but they were to stiff, so I found another pair of Mitsu Eclipse seats. Link to comment Share on other sites More sharing options...
alexinvancouver Posted September 21, 2011 Share Posted September 21, 2011 those are nice i like it when headrests are actually made for ... head to rest Link to comment Share on other sites More sharing options...
hanyou Posted September 21, 2011 Share Posted September 21, 2011 I am thinking about throwing some Outback seats into the Brat eventually, but at the moment I am wanting some Subaru floormats like Alex has. Would love a Subaru logo seatcover as well but am having no luck.. Emailed Subaru themselves and they said they dont have any. Told them I wanted to put the new logo seatcovers on a Outback or Baja, implying I wanted to buy a new vehicle and they told me not to put seatcovers on them, some nonsense about the airbags... Link to comment Share on other sites More sharing options...
