eppoh Posted January 27, 2010 Share Posted January 27, 2010 Trying to run down an 0420 CEL. Does anyone know what the readings should be on the O2 sensors? I'd like to eliminate them before I start replacing converters. Also, any recommendations on scanner software would be appreciated. Link to comment Share on other sites More sharing options...
johnceggleston Posted January 27, 2010 Share Posted January 27, 2010 do a search. some one recently, last few weeks, had a thread with good detail about testing an o2 sensor. what i remember is the voltage on the sensor signal wires was low, real low and fluctuated between or within 2 values as it read the exhaust? if any one remembers who posted it or a key search phrase that would help. do a search. Link to comment Share on other sites More sharing options...
timintc Posted January 27, 2010 Share Posted January 27, 2010 my recommondation is to just live with it. Ive had a 420 code and cel light on for the better part of two years now, tried O2 sensors had a used cat put on and still have the code. Car runs just fine, light is a little annoying but then again so would the grand id have to fork out for a new cat. Unless you have to pass an emissions inspection just live with it, this has been my experience and also the advice of some pretty knowledgeable mechanics. BTW mine is a 2000 legacy wagon with 180k. Tim Link to comment Share on other sites More sharing options...
JohnKos Posted January 28, 2010 Share Posted January 28, 2010 In PA the cel will fail you at inspection time. Link to comment Share on other sites More sharing options...
eppoh Posted January 28, 2010 Author Share Posted January 28, 2010 johnceggleston said: do a search. some one recently, last few weeks, had a thread with good detail about testing an o2 sensor. what i remember is the voltage on the sensor signal wires was low, real low and fluctuated between or within 2 values as it read the exhaust? if any one remembers who posted it or a key search phrase that would help. do a search. Yeah, tried that. Found a link to an article, generic in nature that gave only relative values, and nothing specific to our cars. Link to comment Share on other sites More sharing options...
lewisd Posted January 28, 2010 Share Posted January 28, 2010 I got my code reader from Sears recently for $50. My light was intermittent so I reset the light before I pulled into the emission station here in MD. It passed. I still get the intermittent light with varying codes. still have the fluctuating idle and stumbling occasionally. btw... 99 2.2 legacy auto with 226,000 miles. Link to comment Share on other sites More sharing options...
johnceggleston Posted January 28, 2010 Share Posted January 28, 2010 did you see this one?? http://www.ultimatesubaru.org/forum/showthread.php?t=66744 Link to comment Share on other sites More sharing options...
eppoh Posted January 28, 2010 Author Share Posted January 28, 2010 That link has a good discussion on testing O2 sensors. I am still looking for some recommendations on scanner software. maybe I should start a thread with that title. Link to comment Share on other sites More sharing options...
