Decluttered ea81 hitachi engine bay pics
  spikedbeetle said:
You should be able to remove anything vacuum related and block it off except the line goint to the disty. If that is what you mean.
There are a couple of hoses that go to the carcoal canister that cant be capped off, if you do it tends to not want to Idle down, I have one that is "limited " on hoses, I'll try and get a pick of it as soon as I can.
Jeff
