Decluttered ea81 hitachi engine bay pics
You should be able to remove anything vacuum related and block it off except the line goint to the disty. If that is what you mean.
There are a couple of hoses that go to the carcoal canister that cant be capped off, if you do it tends to not want to Idle down, I have one that is "limited " on hoses, I'll try and get a pick of it as soon as I can.
Jeff
