94Loyale Posted February 4, 2010 Share Posted February 4, 2010 Hey guys. On the Brat I recently picked up, the hillholder is leaking. Not from any of the lines, but the unit itself. Anyone just remove it from the system and tee the lines together? I'd figure that would work just fine, but I wanted to see if anyone else did it. I searched around, but couldn't find anything that helped. Or does anyone have a non-leaking hillholder from a Brat they would like to sell me? Link to comment Share on other sites More sharing options...
AWD TURBO! Posted February 4, 2010 Share Posted February 4, 2010 i have one from a 88 gl if that works Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 5, 2010 Share Posted February 5, 2010 Just replace it with a good used HH - they are common and I'm pretty sure they didn't change the design of the valve much even through the mid 90's in the Legacy, etc. They can be rebuilt with new seals as well. It's not common for them to leak unless water has got into the braking system. GD Link to comment Share on other sites More sharing options...
Gloyale Posted February 5, 2010 Share Posted February 5, 2010 Just replace it with a good used HH - they are common and I'm pretty sure they didn't change the design of the valve much even through the mid 90's in the Legacy, etc. The unit is the same with one exception. However on the later ones (legacy, outback, imp) they only tapped an outlet to one brake(front left IIRC) whereas the old ones have lines going out to both the front left and rear right. the unused boss is still cast into the unit, but the hole isn't drilled or tapped. Seems as though you could "T" out of that one outlet to hook up the two lines out of the original unit. Link to comment Share on other sites More sharing options...
94Loyale Posted February 5, 2010 Author Share Posted February 5, 2010 Well, I do have a good one on my GL10 parts car. But it looks a little different. Basically where the cable attaches. I didn't get a good enough look at it to be positive. Maybe I'll check it out tonight before the snow! I don't care if it works, I just don't want it to leak Thanks for the advice guys! Link to comment Share on other sites More sharing options...
brat82 Posted February 6, 2010 Share Posted February 6, 2010 I need a hill holder cable for 82 brat... Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 6, 2010 Share Posted February 6, 2010 I need a hill holder cable for 82 brat... Dealership. They aren't terribly expensive - best to get a new one. You don't want it binding. GD Link to comment Share on other sites More sharing options...
94Loyale Posted February 7, 2010 Author Share Posted February 7, 2010 Yes, if you are asking if I would sell you mine. You probably don't want it. And GD is right about the dealership, I don't know where else you would find one. Link to comment Share on other sites More sharing options...
brat82 Posted February 7, 2010 Share Posted February 7, 2010 thanks guys, I'll check the dealer Link to comment Share on other sites More sharing options...
