Uberoo Posted February 5, 2010 Share Posted February 5, 2010 it seems the last time I played with my Ea81 toy I must have hit a rut with the lower radiator support.so its bent up a bit.Which was no problem when I wasn't running a hood,but now that Ive found a hood,the radiator is interfering with the hood and not allowing it to shut.Is there a way to bend the support back down or would I be better off cutting the support out and welding some box channel in its place? Link to comment Share on other sites More sharing options...
The Beast I Drive Posted February 5, 2010 Share Posted February 5, 2010 I did this a while back on my Brat. http://ultimatesubaru.org/forum/showthread.php?t=104790&page=2&highlight=workin If its not on that page skip ahead till you get to the part where I rebuild the lower radiator support. -Bill Link to comment Share on other sites More sharing options...
Uberoo Posted February 5, 2010 Author Share Posted February 5, 2010 So what did you do about the tow hook/loops down there?Did you Weld some D rings to it? Link to comment Share on other sites More sharing options...
The Beast I Drive Posted February 5, 2010 Share Posted February 5, 2010 I welded 3/4" thick tabs to the bumpers in-line with the mounting moints on the body, then attached 5/8" clasps to those at each corner. The way I did the front end and the rear end, I gaind almost a whole foot of clearance under the radiator and I gained 8+ inches of clearance under the rear of the bed. When you have a small lift (mine is only 3") you need all the clearance possible. -Bill Link to comment Share on other sites More sharing options...
Uberoo Posted February 5, 2010 Author Share Posted February 5, 2010 do you have any more pics of the whole set up because Im running a 2"/torsion bar cranked up lift.More clearance might be a good thing.. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted February 5, 2010 Share Posted February 5, 2010 do you have any more pics of the whole set up because Im running a 2"/torsion bar cranked up lift.More clearance might be a good thing.. It's all in the thread I linked, look through it from the first page, it's got the lift and all the mods I've done so far. -Bill Link to comment Share on other sites More sharing options...
Uberoo Posted February 6, 2010 Author Share Posted February 6, 2010 Thank you.Now it looks like I need to go borrow a friends welder.What thickness did you use to box the "frame" and mount your bumper to? Link to comment Share on other sites More sharing options...
