White Wheeler Rebuild [ *** 5 DOOR ***]
Scott in Bellingham
time for a change,
since I chopped off the back I havent liked any of the configurations I have, I didnt like the spare tire on the back as I couldnt see out the back to back up, I didnt like the hatch bolted on without being able to open it a sthen I had to reach threw the side door to get the gear and I didnt care for the back being like a pickup caus all my stuff got rained on , so in the shop I go , will end up having a workable hatch,no stock lights at the rear corners and some better protection and clearence at the rear
also other stuff to do
put the dash back in as I havent had one since I replaced the heater core,
replace some or all the doors with straight ones of many colors,
replace the engine as this ones got a bad blown head gasket
at the same time add some Delta torque Cams to that Webered EJ22
may even paint this bad boy bright yellow
here it is stock
picture.php?albumid=76&pictureid=546
first mod I really like this look
picture.php?albumid=76&pictureid=545
pickup style
picture.php?albumid=172&pictureid=1559
the future
Edited by Scott in Bellingham
pics
You could cut lexan on your lathe no oil and just caulk it in. Should cut just fine maybe speed it up a bit. I make jigs on my router, same principal. Stuff glues real well with the right glue, fish tank quality for the corners. I buy scrap per pound for jigs at the plastic shops, you might do better up there.
  • 1 month later...
