idosubaru Posted February 10, 2010 Share Posted February 10, 2010 02 OBW When the wipers are turned on, the drivers side doesn't move but the passengers side does. If I manually pull it up the windshield a bit, it sort of moves back and forth some but overshoots the windshield obviously because that changes it's orientation. So stuff is moving but the wiper arm is not. I'm guessing it was frozen to the windshield and something stripped when the wipers were turned on (I wasn't using the car when it happened). I'm guessing the shaft/nut that holds the wiper blade in place is stripped? I see a small cap, looks like I can pry that up and have a look. I've never messed with EJ wipers - anyone know what it could be? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted February 10, 2010 Share Posted February 10, 2010 pop off the cap and its a 12(or 14)mm nut. same old deal as anything else. if you find the splines are stripped, simply put a lock washer between the wiper arm and the nut. this has worked for me. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted February 10, 2010 Share Posted February 10, 2010 All wiper assemblies are pretty much the same, no matter what make of car. Suggest you remove the nut holding the arm onto the stud, then gently pry and pull the arm straight up off the stud. Once removed, look at the stud to see if the stud splines (grooves) have been damaged. Also, look inside the arm to see if the splines are damaged. Manufacturers usually make the stud out of harder metal then the arm, so if the wiper is turned on with the blade frozen against the windshield, the splines in the arm will strip out first. This makes it a lot easier to replace the arm verses the entire wiper mechanism, called the wiper transmission. If you are lucky, it is just a matter of replacing the arm and blade to fix the problem. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted February 10, 2010 Share Posted February 10, 2010 or possibly tightening the nut on the stud. Quote Link to comment Share on other sites More sharing options...
Suzam Posted February 10, 2010 Share Posted February 10, 2010 or possibly tightening the nut on the stud. +1 on tightening. I had one stop a few year ago. Since the metal is relatively soft a good snugging down should fix it. Mine is still working fine even with snow and ice. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 10, 2010 Author Share Posted February 10, 2010 Sweet that worked, thanks guys. Just popped the cap and tightened the 14mm nut. Don't get much easier than that. I'll try and remember to pull the arm off and check the splines when it's warm or I get power back some week in the future. Quote Link to comment Share on other sites More sharing options...
