spazomatic Posted February 10, 2010 Share Posted February 10, 2010 okay, I've got an '84 GL, 4x4, 4 speed trans. runs great. hitachi 2v is rebuilt, wires, cap rotor, timing (11 btdc), valve adjustment etc etc all in great shape. the only problem is an exhaust backfire in between shifts, or just letting off the gas all of a sudden after I've been "getting on it". sometimes just like a little burble, but the majority of the time, it's like I shot a 9mm. it's so bad, my muffler has actually expanded because of it. if I shift fast enough, I can get to the next gear before she bangs (the tranny synchros hate me) my book says something about an "anti-afterburner valve" but I can't find one, or even more info about it. any ideas there? thanks for reading! Dan Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 10, 2010 Share Posted February 10, 2010 Fix the exhaust leaks in your y-pipe, and block the air suction valve steel tubes with quarters. GD Quote Link to comment Share on other sites More sharing options...
one eye Posted February 11, 2010 Share Posted February 11, 2010 Fix the exhaust leaks in your y-pipe, and block the air suction valve steel tubes with quarters. GD +1 this is the same thing I had going on with mine too, if you have welded on your exaust and it isnt welded up all the way, what will cause it too... Jeff Quote Link to comment Share on other sites More sharing options...
spazomatic Posted February 11, 2010 Author Share Posted February 11, 2010 I have welded on my pipes. I torched a hole in the top of the Y in order to yank the catalyst out, then patched it. but, it is tight. no telltale signs of leakage at all, from front to back. but, I am gonna plug those suction valve pipes and see where that gets me. I sure appreciate the feedback! Quote Link to comment Share on other sites More sharing options...
spazomatic Posted February 12, 2010 Author Share Posted February 12, 2010 you guys rock! $.50 and 5 minutes...done! no bangs, no burbles...just smooth. sweet. Quote Link to comment Share on other sites More sharing options...
Big D Posted February 13, 2010 Share Posted February 13, 2010 Where do the quarter go on the suction value tubes? Which end? Got a picture? Thanks, D Quote Link to comment Share on other sites More sharing options...
Breeke Posted February 13, 2010 Share Posted February 13, 2010 ^^ yeah what he said ?????? Quote Link to comment Share on other sites More sharing options...
eulogious Posted February 13, 2010 Share Posted February 13, 2010 ^^ yeah what he said ?????? :lol::lol: Where do you insert the quarters for the suction thingy... Good times with funny phrases. Quote Link to comment Share on other sites More sharing options...
spazomatic Posted February 15, 2010 Author Share Posted February 15, 2010 wherever you can squeeze them into the rubber line, is where I figured they should go. drivers side, it' the rubber line at the air cleaner. passenger side, it's closer to the pipes (take the tire out). i don't have pics, but you really shouldn't need 'em. just keep air from flowin through the lines. best $.50 I've ever spent Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 15, 2010 Share Posted February 15, 2010 Between the valve and the metal pipe is the best place for the quarters. GD Quote Link to comment Share on other sites More sharing options...
