my loyale...
My 1991 Loyale is having some starting up issues. It will start for about 6-10 seconds, during that time it doesn't stay at a constant idle and if I give a little gas to it she won't rev either very high like past 3000rpm if she revs at all without just dying. I have a new Fuel Filter, Rotor, Distributor Cap, and new plug wires ( I just put new plugs in it ) and I am wondering if these are what I need or what else could it be.
Is this an all of a sudden occurrence? temperature related(cold outside?) has the car been doing this or gradually getting worse?
I would point to the temp sensor, as it will affect how the car runs when cold, or as it warms up
another thing to look for, is under the hood, on the driver side firewall, you will find a pair of green connectors and a pair of white connectors. these are to be UNPLUGGED. the white ones are for pulling engine codes, and the green ones are for setting the ignition timing. if they are plugged in, the timing curve will not advance.
