eppoh Posted February 15, 2010 Share Posted February 15, 2010 Pulling the heads on the 2.2 impreza. Those bolt heads look a little strange., Do they take just a 12 pt socket? Looks like some other pattern, Link to comment Share on other sites More sharing options...
MilesFox Posted February 15, 2010 Share Posted February 15, 2010 12 point socket is correct Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 15, 2010 Share Posted February 15, 2010 Yes - 12pt - that's common with larger bolts when the head needs to fit in a tight clearance area - either 12pt or socket-head. If they made them 6pt heads they would have to be a 16 or 17mm head vs. a 14mm with the 12pt - it gives more grip with the socket over a 6pt or a socket-head. Makes the bolts more expensive but sometimes that's worth it. GD Link to comment Share on other sites More sharing options...
eppoh Posted February 15, 2010 Author Share Posted February 15, 2010 Thanks, I put a 14mm 12 point on it, but it seems that with such a shallow bolt head, there is not much purchase by the socket. The bold head has a skirt and the socket is beveled on the end. Link to comment Share on other sites More sharing options...
naru Posted February 15, 2010 Share Posted February 15, 2010 Thanks,I put a 14mm 12 point on it, but it seems that with such a shallow bolt head, there is not much purchase by the socket. The bold head has a skirt and the socket is beveled on the end. Grind the bevel off,if you need to. Link to comment Share on other sites More sharing options...
eppoh Posted February 15, 2010 Author Share Posted February 15, 2010 Good idea. I shoulda thought of that. Link to comment Share on other sites More sharing options...
