Will 95' Impreza Front seats fit in 87' gl?
hey P i put them in my 89 coupe all you need to do is take the sliders off the imp seats and put the ones from your stock seats on.
Now when you put them on you will bolt the front of the rails to the stock holes on the bottom of the seat and where the back slider holes are you will need to drill a new hole in the seat frame through the existing slider hole and use a nut and bolt with a lock washer. then they drop right in.
Thanks Rob.
spunds very similar to modding XT seats to fit in gl's, you use gl-10 seat tracks to do so with xt's to keep the height adjust feature. Impreza seat sounds easier, actually(dont have to mess with height adjust)
Thanks Rob.
I put Xt seats in my 90 loyale without swapping seat tracks or messing with the height adjust. ?????????
I'm sure he'll need to re use the original tracks, and yes, please post some pics - i'd like to see it
