phantomcrooner Posted February 17, 2010 Share Posted February 17, 2010 I found a set that look like new, the guy pulled them to put in some aftermarket racing seats and only wants 20. bucks Thanks Link to comment Share on other sites More sharing options...
ivantruckman Posted February 17, 2010 Share Posted February 17, 2010 adapter brackets would have to be made. not a drop in swap Link to comment Share on other sites More sharing options...
subaruguru Posted February 19, 2010 Share Posted February 19, 2010 hey P i put them in my 89 coupe all you need to do is take the sliders off the imp seats and put the ones from your stock seats on. Now when you put them on you will bolt the front of the rails to the stock holes on the bottom of the seat and where the back slider holes are you will need to drill a new hole in the seat frame through the existing slider hole and use a nut and bolt with a lock washer. then they drop right in. Thanks Rob. Link to comment Share on other sites More sharing options...
northguy Posted February 19, 2010 Share Posted February 19, 2010 You can make anything fit. As said before, adapter brackets will allow whatever you want. They can be found in the archives. Link to comment Share on other sites More sharing options...
MilesFox Posted February 19, 2010 Share Posted February 19, 2010 spunds very similar to modding XT seats to fit in gl's, you use gl-10 seat tracks to do so with xt's to keep the height adjust feature. Impreza seat sounds easier, actually(dont have to mess with height adjust) hey P i put them in my 89 coupe all you need to do is take the sliders off the imp seats and put the ones from your stock seats on. Now when you put them on you will bolt the front of the rails to the stock holes on the bottom of the seat and where the back slider holes are you will need to drill a new hole in the seat frame through the existing slider hole and use a nut and bolt with a lock washer. then they drop right in. Thanks Rob. Link to comment Share on other sites More sharing options...
phantomcrooner Posted February 19, 2010 Author Share Posted February 19, 2010 Nice, I'll see if he still has them. Thanks Link to comment Share on other sites More sharing options...
phantomcrooner Posted February 20, 2010 Author Share Posted February 20, 2010 The guy just gave me the seats, and provided me with some detailed wiring information to ease my 2.2 swap. Double score! :banana: Link to comment Share on other sites More sharing options...
TheLoyale Posted February 20, 2010 Share Posted February 20, 2010 Post some pics of the seats! -Tom Link to comment Share on other sites More sharing options...
Txakura Posted February 20, 2010 Share Posted February 20, 2010 spunds very similar to modding XT seats to fit in gl's, you use gl-10 seat tracks to do so with xt's to keep the height adjust feature. Impreza seat sounds easier, actually(dont have to mess with height adjust) I put Xt seats in my 90 loyale without swapping seat tracks or messing with the height adjust. ????????? I'm sure he'll need to re use the original tracks, and yes, please post some pics - i'd like to see it Link to comment Share on other sites More sharing options...
