hey there, you may have seen my previous thread on the cooling system of my 97 impreza....well! I have a 98 legacy outback too!!!!
i started the head gasket swap today.
aside from snapping 4 exhaust studs(i used a torch too! the buggers!)
motor is pulled fine.
while she is off, am i right to assume
1: replace timing belt
2: replace water pump
3:replace those dang studs
4: replace t-stat
5........................
why i'm here.
what else should i be doing while the motor is out?
also, while ordering parts in bulk, what is the site most recommended by the gurus? as in low budget quality parts :):lol:
There are a number of things you'd be wise to do while the engine is out and the front end is opened up (idlers, tensioner, oil pump, separator plate, etc.) Try a search--there are tons of threads about it.
If you want genuine Subaru parts at a good price call Jason at Mike Scarff Subaru, 866-528-5282.
