The Dude Abides Posted February 18, 2010 Share Posted February 18, 2010 So before i came across said video i was curious about this if it would work. To some extent if you dont make the pieces to long it reduces the flex they have. Kinda like legos. Could possibly be very strong, say maybe if they had two metal supports in the middle. Will it work. Your going to find out. Link to comment Share on other sites More sharing options...
mcbrat Posted February 18, 2010 Share Posted February 18, 2010 Link to comment Share on other sites More sharing options...
Numbchux Posted February 18, 2010 Share Posted February 18, 2010 yep, I was just going to mention Austin's water wagon 2 Link to comment Share on other sites More sharing options...
The Dude Abides Posted February 18, 2010 Author Share Posted February 18, 2010 Im gonna need a better picture then that. Link to comment Share on other sites More sharing options...
The Dude Abides Posted February 18, 2010 Author Share Posted February 18, 2010 This whole thing came about when i saw others roof racks. Though they were metal and made nicely they sat on top of the yakama roof racks which to me made it just way to tall. Ive configured up a way to use the 2 existing roof bars with a plethara of PVC pipeing which will distribute the weight equally among both sides as well as putting some lighting into play. Just waitng on getting the materials and figuring out the sizes and whatnot. I should be tearing apart the wheel bearing, but this is more fun. Link to comment Share on other sites More sharing options...
bheinen74 Posted February 18, 2010 Share Posted February 18, 2010 that would be lots easier than all the 100 holes, bolts, etc. and be stronger Link to comment Share on other sites More sharing options...
The Dude Abides Posted February 18, 2010 Author Share Posted February 18, 2010 (edited) I wasnt going to do the bolts, but i need to make sure everything is cut up and lined up perfect before i take it apart and paste it together. Ive also been thinking about takeing some cheep angle iron and running it through the center of the long pieces. Might be overkill but it would eliminate all flex in the pipe. Ive also made a call to desmoines steel for some diamond steel flooring:brow: Edited February 18, 2010 by The Dude Abides Link to comment Share on other sites More sharing options...
Numbchux Posted February 18, 2010 Share Posted February 18, 2010 the EA82 roof rails are just riveted onto the sheet metal. not exactly structural. So any roof rack designed to carry any weight (spare tire, jack, etc.) has to be attached to the drip rails. I used to just lay my spare tire on the roof, and the ratchet strap it to the yakima crossbars. kept it very sturdy, but still low. Link to comment Share on other sites More sharing options...
WRX2FFU Posted February 18, 2010 Share Posted February 18, 2010 Making it out of 3/4-1" rigid emt would be cheap and easy too. Ypu could weld or bolt it together using pipe connectors. Link to comment Share on other sites More sharing options...
Ratty2Austin Posted February 18, 2010 Share Posted February 18, 2010 some better pics of my former waterwagon 2... the rack- The PVC/ABS pipe holds up well if you glue it together correctly, and it has many uses- you can drill and screw into it, or use hose clamps to clamp it to/clamp stuff to it, you could even put a fluid/air fitting on there and use it as a storage tank! (non corrosive/fuel, that is!) I did not have any trouble with my rack up there, even with the lights and the goofy overhang- Qman once he saw it, said "your gonna loose that on the first wheelin trip out" and, either I got lucky, or it was tougher than it looked, because it was there just how I made it, 'till I sold the car! Link to comment Share on other sites More sharing options...
monstaru Posted February 19, 2010 Share Posted February 19, 2010 awesome,someone else that needs a nurse......jesus ************in christ Im gonna need a better picture then that. Link to comment Share on other sites More sharing options...
The Dude Abides Posted February 19, 2010 Author Share Posted February 19, 2010 Oh for cripes sakes man i just wanted to see what he did. I have my own darn design in mind. Sheesh. Take it down a notch. PVC didnt come up on the search i did:lol: Link to comment Share on other sites More sharing options...
The Dude Abides Posted February 19, 2010 Author Share Posted February 19, 2010 some better pics of my former waterwagon 2... the rack- The PVC/ABS pipe holds up well if you glue it together correctly, and it has many uses- you can drill and screw into it, or use hose clamps to clamp it to/clamp stuff to it, you could even put a fluid/air fitting on there and use it as a storage tank! (non corrosive/fuel, that is!) I did not have any trouble with my rack up there, even with the lights and the goofy overhang- Qman once he saw it, said "your gonna loose that on the first wheelin trip out" and, either I got lucky, or it was tougher than it looked, because it was there just how I made it, 'till I sold the car! Thanks for posting the pics, im going to be running mine alittle different though. Link to comment Share on other sites More sharing options...
Ratty2Austin Posted February 19, 2010 Share Posted February 19, 2010 Thanks for posting the pics, im going to be running mine alittle different though. No problem I figured i would just throw in my 2 cents... oh, and if anyone is wondering, that basket thingy in the rear section of my PVC rack, is actually the OEM rack basket from a nissan x-terra SUV... it was in the used car department at work, they were removing it and gonna toss it, so I grabbed it and it was funny because it fit perfectly like it was meant to be there! so I just secured the edges with zip ties/hose clamps and it worked out great as a carrier for smaller items (or gas cans and spare tires too) Link to comment Share on other sites More sharing options...
The Dude Abides Posted February 19, 2010 Author Share Posted February 19, 2010 Looks like your running 1 1/2 or 1 1/4 pipe. If so im going to be running either 3/4 or 1inch pipe. Did you try mounting your lights to the pvc but found it was to flimsy. This is someting ive been wondering. Link to comment Share on other sites More sharing options...
mcbrat Posted February 19, 2010 Share Posted February 19, 2010 Looks like your running 1 1/2 or 1 1/4 pipe. If so im going to be running either 3/4 or 1inch pipe. Did you try mounting your lights to the pvc but found it was to flimsy. This is someting ive been wondering. running that smal of pipe, you'll need to cut into smaller pieces with support T's to limit the flex... does a roof rack count as an "option" Link to comment Share on other sites More sharing options...
Ratty2Austin Posted February 19, 2010 Share Posted February 19, 2010 Looks like your running 1 1/2 or 1 1/4 pipe. If so im going to be running either 3/4 or 1inch pipe. Did you try mounting your lights to the pvc but found it was to flimsy. This is someting ive been wondering. Actually, I was running 2" or 3" pipe, (cant remember, but it was not the small stuff!) and I ran the lights off of a metal bar that I had used U-bolts to clamp the bar onto the PVC... I did not have any holes drilled into the pipe at all, it was all attached via hose clamps, zip ties and U bolts. The pipe did flex a little bit from time to time, but like I said earlier, it held up to wheelin' and the weight of things stacked up there! just follow the directions on the primer/glue bottles and you are set! Link to comment Share on other sites More sharing options...
The Dude Abides Posted February 19, 2010 Author Share Posted February 19, 2010 running that smal of pipe, you'll need to cut into smaller pieces with support T's to limit the flex... does a roof rack count as an "option" Yea i know about the short pieces and limiting the flex. Ive got it planned out pretty good but im going to make precision cuts and measure measure measure and try it out before anything gets glued together. Considering ive added a passanger side mirror, cd player, rear discs i have lots of options. Keep that option talk up mr and ill personally autograph your new door:grin: Link to comment Share on other sites More sharing options...
floortom Posted February 19, 2010 Share Posted February 19, 2010 Very cool design....looks great. Sleeping bags ect. Link to comment Share on other sites More sharing options...
