Loyale93v Posted February 19, 2010 Share Posted February 19, 2010 Looking for a copy/download, i.e; of The Factory Service Manual for The 1993 EA82.(Subaru/Loyale) Can any one help me with this? I have most of it downloaded from this site: 1989 EA82 version. Is there much of a difference between the 1989 FSM and the 1993 FSM? I just need the section on Engine cooling. (water pump in particular). Thanks In Advance! Link to comment Share on other sites More sharing options...
eulogious Posted February 19, 2010 Share Posted February 19, 2010 If it's an EA82 car, then there should not be a difference. The Loyale (your car I believe) is the same as a DL from 1989, basically. There might be a few cosmetic difference, but the bulk of the mechanical stuff is the same, so your 1989 FSM should work great for you. I bought a copy of an 1988 FSM to use with my 1990 Loyale Turbo Wagon and so far everything as been the same, including the turbo stuff. I would highly recommend picking up a physical copy of the FSM, very much worth the money. I got mine for $24 shipped Good luck! Link to comment Share on other sites More sharing options...
T'subaru Posted February 19, 2010 Share Posted February 19, 2010 Loyale93v said: Looking for a copy/download, i.e; of The Factory Service Manual for The 1993 EA82.(Subaru/Loyale) Can any one help me with this? I have most of it downloaded from this site: 1989 EA82 version. Is there much of a difference between the 1989 FSM and the 1993 FSM? I just need the section on Engine cooling. (water pump in particular). Thanks In Advance! http://www.ch601.org/engines.htm Link to comment Share on other sites More sharing options...
