Mike104 Posted February 19, 2010 Share Posted February 19, 2010 I posted this on another board and didn't get much response other than a good one from Nipper. I have a 99 OBW with a 2.5L DOHC that needs HGs its got 233k miles on it. I like the car and figure that repairs are better than $500/mo for 60 months for a new car! My question is regarding what options make the most sense for this engine/car. It hasn't overheated and currently transfers coolant from rad to overflow tank. New Subaru Rad cap and thermostat. Option 1: fix headgaskets/replace "while your in there" parts + head checks. Nipper suggested since engine is over 160k to consider replacing short block. Option 2: used engine+HG+while your in there parts. Found a 41k mi used engine for $2k delivered Option 3: rebuilt long block (bare $1700) + while your in there parts Option 4: CCR engine $3500 + install I don't have the tools/equipment/space to do the job myself but have found a local non-dealer who has Subaru experience. Any opinions? I plan to keep the car for at least 5yrs. Its got new tires, brakes, rad, hoses, brakes and battery. Thanks! Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 19, 2010 Share Posted February 19, 2010 Do an EJ22 swap. $1000 or less for a good used engine or donor car and not that hard to swap in. More reliable with a minimal hit on the HP (30 or so). GD Quote Link to comment Share on other sites More sharing options...
Mike104 Posted February 19, 2010 Author Share Posted February 19, 2010 GD, Thanks for the option. May have to look into that if it doesn't get too complicated. Will ask shop to price that option. I'm not generally inclined to do mods (I'm old and boring) but it sounds like a better price for the engine. Not sure what the other costs would be or how they would add up. If I could do this myself (need time, tools and place to work) I would seriously consider going that route, or just fixing it myself! Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 19, 2010 Share Posted February 19, 2010 If you search in the retro-fitting forum a bit it should give you an idea of the job. Basically the engine and exhaust bolt up with no mods. The intake is different so you have to use an EJ22 from an OBD-II car (96 through 99) and a manifold from either an EJ25 phase II, or there are wireing modifications I think that can allow you to use the EJ22 manifold if it's new enough - basically the car's computer will run the EJ22 with no problem - it's just a matter of giving it the manifold w/sensors that it wants. They are MUCH more reliable engines than the phase-I or phase-II EJ25's so if the car is nice it's probably worth the effort. Plus once the conversion is done, EJ22's are a dime a dozen since they rarely fail. GD Quote Link to comment Share on other sites More sharing options...
subaru360 Posted February 19, 2010 Share Posted February 19, 2010 EJ22 is the way to go to keep a 200+ thousand mile car going. Find one with between 100 and 200 miles for dirt cheap, a few hundred dollars. It just bolts in. No modifications needed. Search for the specifics on here. Quote Link to comment Share on other sites More sharing options...
The Dude Posted February 19, 2010 Share Posted February 19, 2010 My advise is to think long and hard before opting for a rebuilt engine. If you get a lemon, usually you will be responsible for the expenses of de-installing the engine, shipping the engine back and forth, and re-installation. And, there is no guarantee that subsequent replacement engines will be any better. If you get a good rebuilt engine the first time, everyone is all smiles and giggles. But if you get a lemon, it can turn ugly and expensive very quickly. Quote Link to comment Share on other sites More sharing options...
