headgasket concern
jasaab
rebuilding a 2.2 1997 Did headgasket but for got to torque down the last 90 degrees on bolts. engine still not in car yet or intake manifold timing belts not on . can I just finish the torque now one week later or do I need to start over with new headgaskets
Edited by jasaab
so long as you did not back any of them out, you are ok. i just did a 2.5 and thought i mixed up one of the torque sequences, but i turned out to be ok. I had to stop in the middle of it and come back later.
there is a angle gauge you can but specifically for degrees turning of head bolts, i guess you would find the tool wherever you can get a torque wrench at. I did not have this yool yo use, i just lined up my torque wrench perpendicular and parallel to the motor to gauge 90 deg turns. I was using an engine stand.
