mkoch Posted February 21, 2010 Share Posted February 21, 2010 My '84 GL needs to have the outer headlights (there are 4 of them) replaced. Presently they are Sylvania 2A1 Sealed type. Are there any better headlight types I can order? Link to comment Share on other sites More sharing options...
monstaru Posted February 21, 2010 Share Posted February 21, 2010 sylvania makes one called a silverstar.....aside from an upgrade conversion , that is about the only choice. they do significantly improve vision, but are still below the par that is today's standard. look around, search a little bit. we all have had issues with night vision in these cars. if i remember correctly, jeszek put in some HID's .....cheers, brian Link to comment Share on other sites More sharing options...
mkoch Posted February 21, 2010 Author Share Posted February 21, 2010 I found these on ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120521805376&_trksid=p2759.l1259 Here is a picture of them Any opinions on these? Link to comment Share on other sites More sharing options...
ihscout54 Posted February 21, 2010 Share Posted February 21, 2010 I used something similar on my car. Keep searching ebay using the lamp numbers you will find better pricing (H4651 H4656 etc). Try "AutoPal". http://cgi.ebay.com/ebaymotors/165mm-H4651-H4656-H1-H4-EURO-CONVERSION-HEADLIGHTS-SET_W0QQitemZ330403004113QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item4ced8dbed1 I will warn you though without upgrades to the wiring/switch you wont be seeing a huge increase in output at all. You might even see a decrease. I have no experiance with the quad-light setup, but Im sure your car uses the same lame negative side switch setup. I rewired mine w/relays and the difference is huge. Link to comment Share on other sites More sharing options...
ihscout54 Posted February 21, 2010 Share Posted February 21, 2010 Just read the link I posted... Sorry the particular set I sent you are for euro-cars, not DOT approved. But the seller has DOT aprvd units in their store. If these are to serve as the brights only it prolly wont matter if they are DOT or not but if they are the hi/lo's then it will. Link to comment Share on other sites More sharing options...
The Dude Abides Posted February 21, 2010 Share Posted February 21, 2010 I have the quad setup and i like the silverstars. Ive heard GE makes a great one called the nighthawk which is suspost to be brighter thent he silverstars. There harder to come buy though. Link to comment Share on other sites More sharing options...
