groningaj Posted February 23, 2010 Share Posted February 23, 2010 This is my problem the soob runs fine for awhile then the only way to get it move is flooring the gas pedal. It will idle fine when this is happening. Started happening after water pump froze, did not have timing belt changed. Not sure what the problem is hoping I can get it figured out. Link to comment Share on other sites More sharing options...
ivantruckman Posted February 24, 2010 Share Posted February 24, 2010 is this a carburated 86 , 4x4 . fuel injected ? any more info may help to diagnose, Link to comment Share on other sites More sharing options...
Kartier Posted February 25, 2010 Share Posted February 25, 2010 check your timing. something like this happened to me a couple months ago. figured out i skipped a tooth. lined it all back up and wala! runs like a champ! hope this helps! kartier Link to comment Share on other sites More sharing options...
groningaj Posted March 2, 2010 Author Share Posted March 2, 2010 More info it is a fuel injected turbo. the engine has around 80,000 4wd. fuel filter is brand new. not sure of any other maintence on the engine. Link to comment Share on other sites More sharing options...
MilesFox Posted March 3, 2010 Share Posted March 3, 2010 i suppose the car rund great until it warms up. and then it is hard to start? i would suspect the coolant temp sensor, try cleaning the terminals on it to see if it improves. the coolant temp sensor is on the back of the intake manifold near the turbo. you might have to remopve a heat shiled to see it. the CTS has the same style connector as the fuel injectors. hope this helps you Link to comment Share on other sites More sharing options...
