EA/EJ Adapter plate, with dowels, without dowels
lostinthe202
I've seen a number (the majority) of adapter plates sold/made/used without the alignment dowel pins. I made one recently and since I had the capability to measure accurately (milling machine) I included the locating dowels in my plate. I did this because the dowels are responsible for keeping the engine and trans on the same centerline which prevents undue wear on all bearings concerned and since I'll be doing plenty of highway driving with this setup it seemed like a good idea.
But I'm curious, how many miles and what kind of driving have people put on their undowel pinned adapter plates?
Will-
Will-
I have two cars both with EJ 2.2 to a EA D/R that have been wheeled offroad for over a year without any dowels and have had no issues
Dowels are needed so that the center of the crank and the center of the transmission input shaft are exactly the same. If they aren't it puts sideloads on the transmission bearings and is generally not good. The bolt holes have slop in them, they're only there to provide clamping force, not allignment.
I've got dowels in mine. If you go to the trouble of machining the plate, poke the 4 extra holes and have it done right.
I highly doubt that unacceptable wear is going to happen from not having the pins. My EA82 has had no pins for 6 years now, same engine, same transmissionn no ill effects of it yet.
I've always pulled engines out that had no pins, for who knows how long and none of the engines suffered from any bearing failure due to anything
