beatupsubaru Posted February 24, 2010 Share Posted February 24, 2010 I just put new axles rotors and pads on the front end of my 1998 subaru legacy outback 2.5 stick. I have an abs light that comes on every once and awhile. along with that I have a sharp return in the brake petal about 80% of the time I am braking it pulsates sharply with a slight grinding noise. I'd love to know what this is so i can fix it cause i am lost. please help me Link to comment Share on other sites More sharing options...
beatupsubaru Posted February 24, 2010 Author Share Posted February 24, 2010 I also seems to have lost all dash lights and have no response from the dimmer on the turn signal lever. Is this a fuse problem or did i break something Link to comment Share on other sites More sharing options...
lmdew Posted February 25, 2010 Share Posted February 25, 2010 The lights and brakes are most likely not related. Check the fuses for the lights. The Brakes should be inspected, checking closly for proper clearance of the ABS Sensor and tone ring. Link to comment Share on other sites More sharing options...
