pearlm30 Posted February 26, 2010 Share Posted February 26, 2010 Quick question. Will the rear hubs out of a MY96 outback auto fit a MY96 outback manual 5 speed ??? Thanks Link to comment Share on other sites More sharing options...
idosubaru Posted February 26, 2010 Share Posted February 26, 2010 definitely. hubs don't vary between manual/auto. the main thing to pay attention to is ABS. ABS hubs have the proper mounting for the ABS sensor but are otherwise the same. So you can install an ABS hub on a non-ABS car (you just have an empty unused hole) but you can't install a non ABS rear hub on an ABS car. Well you probably could if you drill the boss out and drill and tap the bolt hole for the retaining bolt. Link to comment Share on other sites More sharing options...
pearlm30 Posted February 27, 2010 Author Share Posted February 27, 2010 Thanks, they both have ABS. Looks like its going to work:banana: Link to comment Share on other sites More sharing options...
johnceggleston Posted February 27, 2010 Share Posted February 27, 2010 Thanks, they both have ABS. Looks like its going to work:banana: i've never done one, but i remember reading something about an arm? bolt that is a real bolt breaking bear to remove due to rust?. so the general consensus was to leave the arm? on the knuckle and disconnect the other end of the arm from the frame? anyway, some one should know for sure. good luck. edit: maybe not in florida. Link to comment Share on other sites More sharing options...
Mike104 Posted February 27, 2010 Share Posted February 27, 2010 Lateral Link Bolt? Link to comment Share on other sites More sharing options...
idosubaru Posted February 27, 2010 Share Posted February 27, 2010 If there's rust the lateral link bolt won't come out, period. I just did my 1996 Legacy last year which spent it's prior life in Pittsburgh, PA. It has zero rust on it and the bolt came out without much problem. So even the winter, salt, and such didn't hose me on that one. So there's a chance, but often times they're a real bear to get out. If there's any rust definitely a good idea to swap the entire arm. Link to comment Share on other sites More sharing options...
