AWD TURBO! Posted February 26, 2010 Share Posted February 26, 2010 OK well got my rx going 2nd Jen heads with a block that did have under 50k on it but the question is why does the oil psi gage say 75 80 win i start it then falls on its face to 0 at all times? does this sound like a rod? Link to comment Share on other sites More sharing options...
john in KY Posted February 26, 2010 Share Posted February 26, 2010 No. My XT6 essentially has done the same thing for the last 11 years. Replaced the pump and the sender and that changed nothing. The HLAs have never developed the TOD so regardless of what the gauge shows, I know the engine has oil pressure. Link to comment Share on other sites More sharing options...
dragonfire Posted February 26, 2010 Share Posted February 26, 2010 are you use stock gauge? i had that problem with my 88 sedan. i pulled the engine and resealed it new oil pump and water pump. and it still would read the same way. so i installed an aftermarket gauge. so now it goes way upon start up once it warms up it drops to around 5 psi. and moves with throttle position now. hope this helps you some. Link to comment Share on other sites More sharing options...
AWD TURBO! Posted February 26, 2010 Author Share Posted February 26, 2010 well it does 5 psi wow i gees its a subaru but i don't think its an oil psi loss it sounds like a rod just stuck together to go play at sand lake looking in to an EJ swap but don't have the $ to do it Link to comment Share on other sites More sharing options...
MilesFox Posted February 26, 2010 Share Posted February 26, 2010 normal behavior for a stock oil gauge. Link to comment Share on other sites More sharing options...
AWD TURBO! Posted February 26, 2010 Author Share Posted February 26, 2010 (edited) kool so i had oil psi the block just gave it up :-\ it ran good for the day on cheep oil that i will never use again have all ways ran Castrol GTX but not this time... Edited February 26, 2010 by AWD TURBO! Link to comment Share on other sites More sharing options...
