subesandiego Posted March 2, 2010 Share Posted March 2, 2010 Looking for suggestions... I've got a 93 Loyale. Recently had a valve job. Check engine light started flashing on the way home. Returned it to the shop. When we went to check for codes, mechanic realized that the plugs(for checking codes) had not been disconnected prior to starting the engine. Can't get the check engine light to come on now. We've checked the fuse for the computer, the bulb and have given it a couple months to reset. Still no light when we turn the key. Mechanic doesn't know what else to try and can't get the car smogged without the engine light coming on. Any feedback would be appreciated!! Thanks! Link to comment Share on other sites More sharing options...
naru Posted March 2, 2010 Share Posted March 2, 2010 Pull the ECU plug and make sure there is voltage on pin2 (RL) from the bulb w/key on. Link to comment Share on other sites More sharing options...
Gloyale Posted March 2, 2010 Share Posted March 2, 2010 Do any of the warning lights come on? Perhaps the board that the lights are in isn't getting power? The ECU grounds the light to turn it on. So if the board has no power..... Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 2, 2010 Share Posted March 2, 2010 Find a mechanic that can use a MM. Should be a pretty simple fix. Voltage to the bulb, ground at the ECU. And if it's something inside the ECU or you can't otherwise fix it then wire it in so it comes on with the bulb check for the e-brake or something. It's just a bulb check - it's not a deal breaker as far as getting it to pass smog - you can fool those people by simply crossing a wire. GD Link to comment Share on other sites More sharing options...
subesandiego Posted March 2, 2010 Author Share Posted March 2, 2010 Do any of the warning lights come on? Perhaps the board that the lights are in isn't getting power? The ECU grounds the light to turn it on. So if the board has no power.....[All the lights come on except the check engine light] Link to comment Share on other sites More sharing options...
