LSS Posted March 3, 2010 Share Posted March 3, 2010 (edited) When turning right and accelerating my car makes a creaking or popping noise. This is happening at stop light and signs when making right turns. If I make a sharp right hand turn at a faster rate of speed and do not accelerate I do not have any creaking or noise. Any ideas out there what it could be? Could this be a bad CV joint? I just noticed that my boot is cracked too. Edited March 4, 2010 by LSS missing info Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted March 4, 2010 Share Posted March 4, 2010 Welcome to the USMB. I would suspect a ball joint, or possibly CV joint. If the boot is torn, you probably should go ahead and replace the joint while you're doing the ball joints. Quote Link to comment Share on other sites More sharing options...
lionel025 Posted March 5, 2010 Share Posted March 5, 2010 Almost a guaranteed half shaft replacement. They usually cost around $70 and its a pretty quick job. Maybe 1-2 hours. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted March 5, 2010 Share Posted March 5, 2010 Almost a guaranteed half shaft replacement. They usually cost around $70 and its a pretty quick job. Maybe 1-2 hours. Same thought, good chance it is a bad half shaft. Check the rubber boots at both ends of the half shafts for tears in the rubber part. When that happens, over time dirt gets in the bearing to cause wear, resulting in the noise that you are hearing. When wear gets really bad, the joint will completely break down. Quote Link to comment Share on other sites More sharing options...
tcspeer Posted March 6, 2010 Share Posted March 6, 2010 (edited) Also check the bushing at the rear of the front control arm. You can see this right behind the front tires just look up for the two big bolt holding this bushing to the bottom of the car, it will be encased in rubber if this rubber is broke and leaking grease then this will cause your car to pop when turning also. Edited March 6, 2010 by tcspeer Quote Link to comment Share on other sites More sharing options...
LSS Posted March 8, 2010 Author Share Posted March 8, 2010 Thanks All! A new CV Axle shaft on Saturday and it is now ghostly quiet. Quote Link to comment Share on other sites More sharing options...
