I have a 1985-1996 manual. chiltons . the 2.5 specs for head removal and install look the same as my 2000 2.5 manual. The only thing is the cam install is now sohc. there are some torque specs for that as well.
So I would say yes, they are the same as the early torque specs.
Edited by Tahoe Subaru
From FSM (2002 Impreza 2.5 SOHC):
CAUTION:
Use new cylinder head gaskets.
Be careful not to scratch the mating surface
of cylinder block and cylinder head.
2) Tighten the cylinder head bolts.
(1) Apply a coat of engine oil to washers and
bolt threads.
(2) Tighten all bolts to 29 N.m (3.0 kgf-m, 22 ft-
Ib) in alphabetical sequence.
Then tighten all bolts to 69 N.m (7.0 kgf-m, 51 ft-
(3) Back off all bolts by 180" first; back them off
by 180" again.
(4) Tighten the bolts (a) and (B) to 34 N-m (3.5
kgf-m, 25 ft-lb).
(5) Tighten the bolts ©, (d), (e) and (f) to 15
N.m (1.5 kgf-m, 11 ft-lb).
(6) Tighten all bolts by 80 to 90" in alphabetical
sequence.
CAUTION:
Do not tighten the bolts more than 90".
(7) Further tighten all bolts by 80 to 90" in alphabetical
sequence shown in the figure below.
CAUTION:
Ensure the total "re-tightening angle" [in the
former two steps], do not exceed 180".
Cheers!
Edit: Funny.. If you do a google search for "S2M1589B" there are a couple sites with this section of the FSM PDF online.
Edited by nickb21
Added image, link.
