Uberoo Posted March 7, 2010 Share Posted March 7, 2010 (edited) 1: what is the proper way to remove the inner tie rod ends on an EA81 and EA82? 2:just making sure here: All NA manual axles have the same splines regardless of FWD/4wd correct?I know the turbo/auto axles are different. 3: Are the front brakes on an EA81 the same as EA82 front brakes?If not same will they atleast bolt up? Edited March 7, 2010 by Uberoo Link to comment Share on other sites More sharing options...
ivantruckman Posted March 7, 2010 Share Posted March 7, 2010 (edited) found this thread below Edited March 7, 2010 by ivantruckman Link to comment Share on other sites More sharing options...
ivantruckman Posted March 7, 2010 Share Posted March 7, 2010 the inner tie rods just unscrew, they have a washer that bends over the joint to keep it from coming loose . its real simple. this thread has pics http://www.ultimatesubaru.org/forum/showthread.php?t=97513 Link to comment Share on other sites More sharing options...
Uberoo Posted March 7, 2010 Author Share Posted March 7, 2010 ok anyone have any idea about brakes? Link to comment Share on other sites More sharing options...
TomRhere Posted March 7, 2010 Share Posted March 7, 2010 Brakes are different, won't fit. Link to comment Share on other sites More sharing options...
Phizinza Posted March 7, 2010 Share Posted March 7, 2010 The knuckles have a different roll radius. The calipers have a larger bolt pattern. And the discs are a little bit bigger. Also the rear bearing seal on the knuckle on EA82's are slightly larger, thus why EA82 axles won't work too well in EA81 knuckles. It will all bolt up, but you will have horrible positive camber. Link to comment Share on other sites More sharing options...
