SubeeTed Posted March 8, 2010 Share Posted March 8, 2010 Hi ALL! I need to reattach my door trim to my '97 GT Wgn. I'm going to use good old Bondo, basically as glue. Is it still too cold here in MAss to use it? It's going to be maybe 50 today, i'll point the car into the sun to help out. Any ideas? Many thanks, SubeeTed Link to comment Share on other sites More sharing options...
OB99W Posted March 8, 2010 Share Posted March 8, 2010 [...] It's going to be maybe 50 today, i'll point the car into the sun to help out. [...] You could try a test batch, but that temperature is probably too low --read the directions. See http://www.roadsters.com/filler/ , a pretty good write-up where 64 degrees F is stated as minimum temp for curing. Link to comment Share on other sites More sharing options...
Rooster2 Posted March 8, 2010 Share Posted March 8, 2010 IMO, bondo would not be a good gluing product. It just won't adhere well under any circumstances. The only thing that it will really adhere to a car is paint. Also, bondo won't "set up," to dry or harden unless the temp is in the 70's. I guess you could try it for temporary use. If so, use a hair dryer to heat and dry the bondo. I think you would be better off using some good glue, or even a trim adhesive that would be designed for that purpose. Link to comment Share on other sites More sharing options...
nipper Posted March 9, 2010 Share Posted March 9, 2010 Read the recomendations on the Bondo, but i think 50 may be too cold. Link to comment Share on other sites More sharing options...
Allpar Mod Posted March 9, 2010 Share Posted March 9, 2010 Basically, you need an ambient air temperature of at least 65 degrees for any brand of body putty to work properly. Use it below that and it will not cure properly. Bondo is a bad choice for trim attachment. You'd be better served heading to your local body shop supply and getting some 3M trim adhesive. Barring that, you can use any silicone adhesive. With either, make sure you tape the trim down securely after applying the adhesive for 24 hours to assure a good job. Still, even with these, it might be too cold yet. Link to comment Share on other sites More sharing options...
OB99W Posted March 9, 2010 Share Posted March 9, 2010 Oh, well if we want to do the job right, ... There are all kinds of adhesives, etc. (including double-sided tape, which for certain purposes is a simple solution) that 3M has for automotive applications. Click on the links at the left of the following page for lot's of info: http://solutions.3m.com/wps/portal/3M/en_US/Automotive/OEM/ Link to comment Share on other sites More sharing options...
bobaru Posted March 9, 2010 Share Posted March 9, 2010 Bondo DOES NOT stick to paint. ONLY bare metal. Link to comment Share on other sites More sharing options...
OB99W Posted March 9, 2010 Share Posted March 9, 2010 Bare metal is the preferred surface. However, if the paint is free of wax and is clean, dry, and especially if sanded to provide some "tooth", the filler will stick quite well. But that still doesn't make it the best choice for attaching trim. Link to comment Share on other sites More sharing options...
